hall36034
Posted: Thu Dec 04, 2008 2:53 pm Post subject: 20" Sanyo DS19230 compelety dead |
Sanyo 20" TV
Model DS19230
Chassis 19230-01
I accidenty shorted the fuse out to the ground and now It's completely dead, I replace the fuse and still it will not power up.
Thanks for your help and advise |
Posted: Thu Dec 04, 2008 3:41 pm Post subject: |
If it is the line fuse, have you checked to see if you still have AC coming out of the house recepticle?? Maybe you popped a house breaker.
hall36034
Posted: Thu Dec 04, 2008 3:55 pm Post subject: |
I have AC coming out of the house recepticle and 120v is on the fuse,
maybe something else in the set? |
Posted: Thu Dec 04, 2008 5:23 pm Post subject: |
If you shorted the line fuse to ground, you need to look at the foil side of the chassis and inspect for any blown foils. I looked on the sanyo website and they do not list your model but they do list a DS19330. I would also check the bridge rectifiers and the surge resistor (large white resistor) for damage.
hall36034
Posted: Fri Dec 05, 2008 9:03 am Post subject: |
I looked at the foil side of the chassis and inspected for any blown foils,and I found blown foil at D023 and CO23
I check the bridge rectifiers and the surge resistor (large white resistor) for damage, and they are ok..
Jesse, You were right about the blown foil,,
what can I do about the blown foil,, thanks hall36034 |
Posted: Fri Dec 05, 2008 11:01 am Post subject: |
Install a Jumper wire or obtain a fiberglass brush here http://www.mcmelectronics.com and use the word "fiberglass" in the search engine. (first line Item)
If you obtain the fiberglass brush, clean the coating from the trace on both sides of the break and install a soldered in jumperwire of the appropriate size (dependant on the foil size).
Hope this helps.
