codenameziggie
Posted: Tue Jan 27, 2009 12:11 pm Post subject: 27 inch phillips magnavox RP2648 B101 chassis#27x102-00AA |
My tv started to act strange a few days ago,it started with the picture starting to flip like a virtual hold problem,so i just unpluged it and waited a few hours,then when i went to turn it back on it just displayed a whitish gray screen with lines,the sound is fine,and it gets brighter when left on,but it dont shut itself off or anything,I can turn it on and it stays on till I turn it off,I have found some info with that kinda problem that im having,but they all say their tv's shut themselves off and something about a r3304 or sum suck 10 ome resister on the crt board I have looked for this and I dont see anything like that? I hope someone can help me with this,I know this tv is kinda old it was made in 1993,but it has been left to me by my passed uncle so it means alot to me if I can get it working again, thanks to anyone that might be able to help me |
Posted: Tue Jan 27, 2009 1:29 pm Post subject: |
Chassis number?? (should be on same id tag as model)
codenameziggie
Posted: Tue Jan 27, 2009 3:02 pm Post subject: |
im sry the chassis number is 27x102-00AA |
codenameziggie
Posted: Tue Jan 27, 2009 3:09 pm Post subject: |
im sry i i hit the wrong key it is a model RP2748 B101 chassis#27x102-00AA |
Posted: Tue Jan 27, 2009 4:09 pm Post subject: |
This tv uses discrete components for the CRT drive.
Measure the collector voltage on q1, q2, q3 of the crt pcb. Should be 117VDC ~ 122VDC.
Also measure on both sides of R13. CAUTION, There will be around 300~600 VDC at this point. If you touch, Oh the pain!!
A good ground point will the the tuner shield or anything that reads O ohms to the tuner shield.
