solder_what_now
Posted: Wed Oct 28, 2009 8:32 pm Post subject: 32A42A Toshiba, IR is dead? |
Ok guys, this is my first post.
now that the formalities are out of the way.
I just picked up a Toshiba CRT from a friend.
Model 32A42A
Chassis: TAC 0248
Remote model - CT-90037
I get the tv to my place, and i find out the remote isn't working.
I check the batteries, i try programming other remotes. I even get a digital camera out to check that the remote is throwing a signal. That all seems good.
The tv works fine, the sound's good, picture's clear, but currently through the remote i can't operate the tv. - depressing.
It's managable, the remote for the cable box changes the channel, but i never realized how important the volume feature would be, th epower would just be nice for the whole power bill aspect.
I have no real problem opening this TV up, but my issue is i'm not sure of what kind of replacement parts i should be looking at, and also haven't been able to find any in my searches. I've browsed Ebay for parts and Googled for service manuals and i'm coming up dry.
Any ideas or resources would be greatly appreciated. A service manual to glance through of this tv or similar would be greatly appreciated. I like to have an idea of what i'm doing before i tear apart things that arn't completely broken. |
Posted: Thu Oct 29, 2009 12:39 pm Post subject: |
First, before you spend any money, look in the owner/operators manual for your CABLE BOX REMOTE. Just about all cable box remotes are programmable. Program your cable box remote for your set. There should be several different codes available for Toshiba.
I did check the reference for your set and the remote model is correct for that set.
One of the more common failures in this area is water damage on the board. (someone cleans the glass and the liquid runs down the glass, goes behind the excutcheon and drips on the circuit board.) Many times the remote reciever is what gets trashed.
The part number for the reciever is 23007490 and is available here: http://www.andrewselectronics.com/welcome.aspx
costs $9.26 plus shipping and is a soldered in device.
solder_what_now
Posted: Thu Oct 29, 2009 4:33 pm Post subject: |
Thanks for the quick information.
I've already tried the Toshiba codes on two other controllers (one a Comcast, another a OneforAll) I have even attempted the code search which after about 100 tries, i came to the conclusion it was the receiver.
I am having a little issue finding the part number you supplied on Andrews electronics, does it require a username to search for parts?
Once i can verify this part, guess the next step is to find some one to help put the tv on the ground and start researching disassembly.
I already know about the crt discharge, hopefully this reciever isn't too confined considering ill have to remove it and put another in. |
Posted: Fri Oct 30, 2009 3:52 pm Post subject: |
After accessing the website, look in the blue field top right area and click on "order parts". Then on the center right edge click on find parts (small print in Orange) of the consumer parts orders area. After that simply insert part number.
The device is small and you have to remove the main board to access.
If you are having trouble with this I would suggest you ask someone with good soldering skills to help
solder_what_now
Posted: Fri Oct 30, 2009 7:27 pm Post subject: |
I swear I'm not fishing for posts.
I had already found the part search area, my issue is i never get any results when i search. I'll post a picture as proof once i find some web space and a little time.
I've tried with Google chrome, Firefox, and also IE 8 (ugh). Maybe i have something blocked in my hosts file, i'll try that next.
All have returned the same results.
are you sure this is the number 23007490
Is the formatting correct, are there any hyphens or asterix preceding or in it? Is it necessary to have a manufacturer in the search field, I've tried blank as well as Toshiba.
As for me being able to make the repair, i have to tear the television apart first to see what surrounds this component. Once that occurs, i'll way the risk vs my willingness to not have half the functionality of the remote.
Note: just altered the hosts. still coming up dry |
solder_what_now
Posted: Fri Oct 30, 2009 8:08 pm Post subject: |
[img]http://i1005.photobucket.com/albums/af171/solder_what_now/search.jpg?t=1256954702[/img]
Also, while just brute force searching for the part by searching for 2300, the part number you listed just seems to not exist, theres a gap.
Toshiba 23007396 PCB *NLA*TAIS
Toshiba 23007664 COVER, BACK 36AFX61 BACK COVER CABINET |
Posted: Mon Nov 02, 2009 12:51 pm Post subject: |
My bad, part number = 23009490
This website also has a search engine albeat you have to use the "order part" section to access the search engine via model number.
However, it is still "MY BAD"
