53" phillips projection problem
tsgtwheeler
PostPosted: Fri Oct 09, 2009 4:11 pm    Post subject: 53" phillips projection problem Reply with quote
i have a 53" phillips projection screen that when we turn it on the red is seperated or this is the only one i can tell. after i turn it off and on several times this will correct its self for the rest of the day unless i turn it off for a while. i have cleaned it very well. in the green bulb looks like a bug is in the middle of it. is there a way to pull this apart and fix it. could this be the reason it seperates or do i need a full conveyenc. i have never heard of it correcting its self like this.
thanks in advance for any advice
PostPosted: Fri Oct 09, 2009 10:22 pm    Post subject: Reply with quote
model?
