Acer 17" AL1714 lcd replacement
2ndhandsony
PostPosted: Sun Mar 21, 2010 10:58 am    Post subject: Acer 17" AL1714 lcd replacement Reply with quote
Have an Acer AL1714 17" lcd monitor with a hole in the screen. I also have an Acer AL1715 17" lcd monitor,good screen w/bad powerboard. Can I swap lcd screens,are they interchangeable? If not;does anyone have the part number for the AL1714 replacement screen or a used screen for sale? thanks
PostPosted: Sun Mar 21, 2010 6:19 pm    Post subject: Reply with quote
The screen (as you call it) is composed of the TFT (glass) panel and the panel driver PC board (this will have a reference number on it). The two are connected via a fragile/flexible film that is NOT detachable. The most important things are does the panel fit in mounting frame correctly, does the panel driver board have same reference number (and physically will align with the mounting holes), and does the LVDS cable fit socket on panel driver board.
