Akai 70CM TV Green Screen
Jan
PostPosted: Fri Jul 22, 2011 1:41 am    Post subject: Akai 70CM TV Green Screen Reply with quote
AKAI Model CT-T29S33A - FAULT IS GREEN SCREEN BUT PICTURE IS GOOD WITH COLOR. I HAVE FOUND A BURNT 1/2 W RESISTOR ON THE PCB P/No E3701-002020-1 WHICH PLUGS INTO THE BACK OF THE CRT. PROBLEM IS THAT I CAN NOT READ THE COLOR BANDS ON THE RESISTOR TO DETERMINE THE RESISTANCE. THIS RESISTOR CONNECTS TO CN2001 PIN 7 MARKED +130V. OTHER MARKINGS ON THIS CONNECTOR IS GND, SW, YS & Y. I DON'T KNOW FOR SURE IF THIS RESISTOR IS THE CAUSE OF THE PROBLEM. PERHAPS YOU CAN SUGGEST WHAT ELSE I SHOULD CHECK IF THE PROBLEM PERSISTS. AT THIS STAGE I WILL APPRECIATE IT YOU CAN SUGGEST WHAT VALUE RESISTOR I NEED, TO REPLACE THE BURNT OUT ONE WITH.
YOUR ASSISTANCE WILL BE MUCH APPRECIATED
