AKAI PT61DL34 -audio bad, echo, distortion, popping noise
DGC
PostPosted: Mon Dec 30, 2013 8:43 am    Post subject: AKAI PT61DL34 -audio bad, echo, distortion, popping noise Reply with quote
Have an AKAI 61" dlp - modelPT61DL34. Resently replaced the bulb and ballast. Now the sound is bad.
When first turned on it is fine. after a few min. the sound gets distorted - has a tinny echo in it. Sometimes there are popping noises. If you turn it off for a few min. it comes back normal but will turn bad again in a few min.
