Bush LCD27TV No power, no standby
Ulric
PostPosted: Sat May 15, 2010 9:44 am    Post subject: Bush LCD27TV No power, no standby Reply with quote
Hello there,
I have a Bush (LCD27TV) LCD TV which worked perfectly until today.
However it won't turn on anymore: no picture, no sound, no standby, no front led...
On one of my first attempts to switch it on this morning, it very briefly turned on, displayed some snow, and switched off again after less than half a second. Since then, it has never turned on again.
At first, when power was on I could hear a very faint high pitched sound from the top of the monitor, but can't hear it anymore.
I tested for the wall socket, which works properly.
I opened the back of the TV but fuses don't look obviously blown, and no components look blatantly burnt.
The sudden onset of the fault and the fact that there doesn't seem to be any power going through the TV at all makes me think that the power supply may be faulty, but I may be entierly wrong!
Have you ever come across this kind of issue?
Could I fix it myself or should I call a repair man?
And if so, how much might it cost?
Thank you very much!
Ulric
PostPosted: Sat May 15, 2010 3:53 pm    Post subject: Reply with quote
The TV switched on again and has now been working for an hour...
I wont complain, but it makes it even more weird and I would really like to understand!
Neutral
Any idea?
Thanks! Wink
