Curt Palme
Joined: 22 Sep 2010 Posts: 2 Location: Vancouver, Canada
Posted: Wed Sep 22, 2010 8:33 pm Post subject: |
You need to go right to the manufacturers..who may be helpful... or not.
Most are pretty easy- switching power supply and two or more amps within the unit. Some parts are a PITA to get, and you'll most likely find that most are not worth repairing. I got lucky with some AS IS Pioneers on eBay a couple of years ago, I got four for just under $100, and three had a broken trace from the 'turnon' terminal to the amp. A design fault I guess, the traces were really thin.
Some amps will do a big smokeshow if designed poorly. Also, if you're dealing with SMT devices, you can ruin the unit if you don't have the proper tools to desolder them. I did that with a small Fosgate that I was practicing on. Good luck! |
