rrobor
Posted: Sat Jul 18, 2009 1:57 am Post subject: Correct method to discharge a CRT |
How to discharge a CRT without killing yourself works, pitty by this method you can kill the micro or corrupt an Eprom. You must always discharge the crt to the aguadag or the strap on that. Ite aquadag often is not at chassis potential so if you charge the chassis it will reverse bias many things. |
Posted: Sat Jul 18, 2009 6:34 am Post subject: |
thanks for bringing this to my attention. I have done the method shown here many times with no issues... yet
So, how does one attach the to the aquadag? |
Posted: Sat Jul 18, 2009 2:53 pm Post subject: |
Some are at chassis ground potential, some are not.
Most manufacturers have a (sometimes) spring-loaded "strap" that (usually) also connects to a main chassis ground and a stake on the CRT neck board.
Philips connects to a stake on the main board near the flyback.
Just take your finger nail, pull outward on strap and insert wire, alligator clip, etc.
See: http://en.wikipedia.org/wiki/Aquadag |
rrobor
Posted: Thu Jul 23, 2009 7:28 am Post subject: |
A pro would use 2 screwdrivers in a crossed sword config, its quick and easy. Even when Philips supplied a spade most techs never used it. |
Posted: Mon Sep 21, 2009 12:31 pm Post subject: |
I updated the tutorial with your suggestions. Thank you. |
