marleythedog
Posted: Wed Dec 24, 2008 11:49 pm Post subject: CTC169 Picture Degradation and Tuner |
Hello,
I have had for a couple of years an RCA F27227EM, chassis CTC169CF2, mfg. 1992. I got it as a freebie, believe it came from a restaurant. It's had a couple of long-standing issues and one that cropped up just recently. I'm relatively amateur at electronics repair, but if my issues are fixable I have nothing to lose in trying.
Picture-related issues: There's been red shadowing of highlights on the screen for as long as I've had it. Within the last couple of weeks, a high-pitched sound is emitted from the board when AC is plugged in and red horizontal retrace lines appear on the screen within about 60 seconds of power on. In my attempts of self-diagnosis, a lot of 169 tips online related to picture suggest replacing various caps/diodes in the deflection circuitry. Does this sound relevant to my issues?
Tuner: Signal often drifts to snow and back while tuned on any channel. We got around it using by using a cable box on a/v input. I read about the bad soldering issue with 170s/180s tuners, and though my symptoms were the same, I didn't see any mention of this being a problem on the 169 chassis. Might this be the case anyway? The tuner innards look like the one in the 175 diagram on repairfaqs.
Being it a 16 year old TV and a CTC169 furthermore, is it worth messing with? I certainly would not pay to have it repaired, but if I can hobble a few more hours out of it with a few bucks in parts and some patience, I'd certainly be willing to try. I'm about as amateur as they get, and don't have much more electronics equipment than a multimeter and a soldering iron.
Thanks and merry Christmas,
Chase |
ivtec
Posted: Thu Dec 25, 2008 6:37 pm Post subject: |
Try to lower g2 on the back of the flyback transformer and see what happens. |
marleythedog
Posted: Thu Dec 25, 2008 10:16 pm Post subject: |
Lower g2 eliminates retrace lines. Too low stretches the red shadows in some scenes however red shadows are completely unaffected by g2 in others. The picture has a slight red cast in general with black looking like dark maroon. Turning screen down 'til black is black exacerbates the red shadowing and makes the picture pretty dark. |
Posted: Fri Dec 26, 2008 8:38 am Post subject: |
if you cant get it looking good in the customer menu, I think your tube is probably shot. You can try rejuvenating it. that often has limited success. basically your CRT is worn out and used up. |
Wendell1980
Joined: 30 Dec 2007 Posts: 74 Location: Cambridge, Ontario, Canada
Posted: Fri Dec 26, 2008 12:23 pm Post subject: |
videodisplay in the states can rebuild tubes just had all 3 done for my sony |
Posted: Sat Dec 27, 2008 7:34 am Post subject: |
how much did that cost Wendell? |
Wendell1980
Posted: Sat Dec 27, 2008 9:11 am Post subject: |
it cost me 165 dollars american per tube |
