mrd31486
Posted: Fri Feb 18, 2011 11:36 pm Post subject: D52W20 Vertical issue? |
It seems I have fixed the other issues with this set. The problem that still remains is that the image is very blurry. It appears the image is smeared from left to right. Appears in all inputs and menus.
When I try to adjust convergence, the horizontal lines are bright and clear. The vertical lines, however, are so dim that they are nearly invisible. I'm not sure exactly what would cause this. Should I start probing the vertical circuit? Any ideas??
Thank you! |
