Difference Between Digital and Analog TV Antennas
GBertolet
PostPosted: Sun Jan 20, 2013 4:55 pm    Post subject: Difference Between Digital and Analog TV Antennas Reply with quote
I have one of my tv's on the antenna, using my digital converter box. It's in an outlying part of the house where there is no cable co-ax run. I am experiencing tiling and occasional breakup on all channels, especially the higher band, (old UHF) channels. I am using a rabbit ears antenna, equipted with a seperate UHF antenna. For a test, I even ran a temporary coax to my old outside antenna, getting similar results. I see dedicated digital inside antennas are being marketed. Is there a difference, to warrant purchasing one? If so, what is the difference?
oryan_dunn
PostPosted: Mon Feb 04, 2013 10:01 am    Post subject: Reply with quote
No difference. A good UHF antenna is a good UHF antenna regardless of the signals it's receiving. Ditto for VHF. I'd look at the range rating for the antenna, that you've got it pointed in the correct direction, and that you have good quality RG6 or RG6Quad for the cable runs.
PostPosted: Mon Feb 04, 2013 7:25 pm    Post subject: Reply with quote
The nature of radio frequencies HAVE NOT CHANGED since the Analog to Digital switchover. "Channels" STILL occupy the same frequencies now as before. (FOR EXAMPLE: Channel 47 frequencies are still for channel 47).
"STATIONS" (ABC, CBS, PBS, etc.) may have moved from VHF to UHF (or visa-versa) or from one UHF channel assignment to another.
If you had marginal quality reception on Channel 47 BEFORE the changeover, you probably will have an impossible chance of getting it NOW.
