Dish Network TV AKA RCA ATC 221 chirping
Ben's Tv
PostPosted: Sat Nov 01, 2008 11:09 pm    Post subject: Dish Network TV AKA RCA ATC 221 chirping Reply with quote
I have a hd40-300 Dish Network TV has a RCA ATC 221 chassis Set will get make a chirping noise as soon as it is plugged in and then stops after 2-3 time I have no LED light on the power button.Now I have seen 3-4 topics with ITC222 but none on ATC 221.I get 168 V to TP020 which is suppose to be 300V and i can't find where i'm losing the 132V at.I replaced a cap cp120 330UF @35V it was bulged and only got 130UF so put the exact replacement cap and no difference any help will be appreciated
T.I.A (Thanks In Advance)
PostPosted: Sun Nov 02, 2008 8:25 am    Post subject: Reply with quote
http://www.riddledtv.com/repair/RCA/ATC221.html
Ben's Tv
PostPosted: Mon Nov 03, 2008 4:45 pm    Post subject: Reply with quote
Thanks hurdler for the info. i checked the standby regulator and it read fine checked a couple more caps i think it was cp411 and it was reading weird like it is suppose to be 2200uf well it jumped up to 4000uf and dropped down to 2600uf so i thought it just needed discharged so i did and tried it again and it had the same readings so now im going to replace it and see what happens.
