_Troy Guest
Posted: Thu Feb 26, 2009 12:24 pm Post subject: DP42647 Sanyo |
I have a DP42647 Sanyo with a shorted diode d905 shorted. Looks like will
fix the Tv but cant find a sub or part no. Has anyone had this problem. I
hate to buy the whole board.
Troy |
_Brad Guest
Posted: Thu Feb 26, 2009 12:25 pm Post subject: |
is it a dp42746? |
_Doug Guest
It is probably an MBRB2060G. You might have to find a sub. |
_Troy Guest
Posted: Thu Feb 26, 2009 12:26 pm Post subject: |
It is mbrf2060ctg. I just found some at Mouser electronics. Ordered some.
Sanyo want furnish the parts for this board. They want you to buy whole
board. I t is getting out of hand with these companies and the prices they
want for these boards. Customers are going to start balking at this rate.
Thank you guys for checking. Hope all have a nice weekend. |
_Darryl Guest
Troy:
Can you send me the PDF of the DP42746 service manual? I recently discovered
some of these Norcent Plasma sets are very close in design. The Norcent
service manual is a joke! Thanks in advance. |
_JOhn Guest
Posted: Thu Feb 26, 2009 12:27 pm Post subject: |
Troy is this a TV or LCD or Plasma, and what part is this on the P/s? |
_Troy Guest
Doug, I have a dp42647 LCD instead of the 746 Plasma. I'm sure there are very different. I will look and see if I can find a manual on the one you need. I will get back with you.Troy |
colormebad
Posted: Sat Mar 05, 2011 12:34 pm Post subject: Diode ? |
Anybody every figure out if the diode was the only problem or where their more problems....Thanks |
pblmk2002
Posted: Fri Apr 22, 2011 4:42 am Post subject: if you have the service manual for sanyo dp32647, i need als |
Troy:
pblmk2002
Posted: Fri Apr 22, 2011 4:46 am Post subject: sanyo dp32647 |
Troy, if you have dp42647 SM and norcent, I would sure appreciate receiving them. |
