Element ELDFT406 keeps shutting off
c000159
PostPosted: Mon Jan 27, 2014 7:24 am    Post subject: Element ELDFT406 keeps shutting off Reply with quote
When using the HDMI, VGA or RCA inputs, the TV will play for about 10 minutes and then shut off. It will turn back on though and stay on again for about 10 minutes.
When using an HD antenna with the cable in port, the TV works perfectly and never shuts off. But, if I use a RF modulator and and try to watch a DVD player or my surveillance DVR through the cable in port, it will shut off again. This really doesn't make sense!!
I've replaced all but two of the capacitors on the power supply board. I did this before I found out about it working properly with a HD antenna. The capacitors I did pull all checked out OK. So I don't think it's a cap problem. And I don't think it's a power supply issue. I'm guessing it has to do with the main board where all of the ports plug into.
Anyone have any suggestions?
Thank you!
