Rotnak
Posted: Fri Sep 01, 2017 11:45 am Post subject: Element ELEFW504 - Dead |
I have an Element ELEFW504. Lightening hit nearby and now have no power to TV. Nothing else in house was damaged (weird). I have been told there is a fuse but cannot find one or don't know what it looks like. Can anyone help me identify the fuse so I can buy a new one?
Thanks,
Mike |
Posted: Fri Sep 01, 2017 4:23 pm Post subject: |
MANY different versions of each board your TV Model may use. You'll need to tell use which one(s) your set uses.
Power boards all seem to have the Red/Rectangular main AC fuse immediately next to where AC cord plugs into the board. There are probably other fuses besides the AC fuse. |
Rotnak
Posted: Fri Sep 01, 2017 5:50 pm Post subject: |
If this is the board number it is TP.MS53393-PC821
There is a mauve/clay colored rectangular shaped directly in front of where the power cord comes in and plugs in. It says "13.15A.250V"
It also has triangle like a yield sign with the letters "SA" inside, another triangle with the letters "VDE" inside, an oval with the letters "CQC" inside and a diamond shape with the letters "PSI" inside and the word "JET" directly under it. All of this is very small and I had to use a magnifying glass to read this.
Hope this helps. |
Posted: Fri Sep 01, 2017 7:26 pm Post subject: |
...and its soldered to de board.
By clicking on the link in my last post (the blue MANY) you would be taken to a site that shows the various versions of your sets boards. How to identify board part numbers and has high resolution, multiple enlargement photos. |
Rotnak
Posted: Mon Sep 04, 2017 2:46 pm Post subject: |
Yes it is soldered.....on the link you supplied me, it is the clay colored object directly in front of white power line (incoming) connection
Thanks again |
