Emerson LC320EM8A Fix for dead set.
kb9ekh
PostPosted: Sun Mar 08, 2009 12:21 am    Post subject: Emerson LC320EM8A Fix for dead set. Reply with quote
If no standby light is present and fuse is not blown, check D633 for short. Located on the board for secondary voltages and audio.
PostPosted: Sun Mar 08, 2009 7:28 am    Post subject: Reply with quote
Thanx for the tip
tthavorides
PostPosted: Fri May 29, 2009 12:30 am    Post subject: emerson LC320EM8A with shorted D633 diode Reply with quote
is there a likely cause for this shorted diode or will replacement be all that's necessary for the fix? I get 0.1 ohms resistance between anode side of diode connection and ground.
PostPosted: Fri May 29, 2009 5:30 pm    Post subject: Reply with quote
kb9ekh Only mentions the diode.
You're measuring the SMPS transformer winding Exclamation
Pull (at least) one lead of the diode out of the circuit. Use the "Diode test" function of your DVM and test across it with Red lead on marked (line/cathode) and Black lead on other. Then test across it with Black lead on marked (line/cathode) and Red lead on other. You should get "Infinity"
/ "Over Range" one way and "some" reading the other way.
tthavorides
PostPosted: Thu Jun 04, 2009 1:23 am    Post subject: Emerson LC320EM8A Reply with quote
Replaced shorted D633 diode, TV works great. Many thanks!
