Firmware update LG 26LX1D TV Guide On Screen (TVGOS)
stevekerr
PostPosted: Thu Nov 19, 2009 10:19 am    Post subject: Firmware update LG 26LX1D TV Guide On Screen (TVGOS) Reply with quote
I have an LG 26LX1D.
My TVGOS stopped working after the digital switchover. I tried rescanning channels and resetting the zip code to 00000 then back to my zip. No dice. I then saw a forum post about firmware. As I understand it, the firmware has to be later (higher) than version 8 rev 65. I was able to run the diagnostic code on my TVGOS that told me I have version 8 rev 29.
So I think I need the firmware updated. I have no idea where to get that or how to do it though. Anyone here that can walk me through it? Or is my TVGOS dead forever?
PostPosted: Thu Nov 19, 2009 11:07 am    Post subject: Reply with quote
Firmware is not your problem.
You must have your set set in antenna mode - not cable mode - to recieve digital terrestial signals. If you have your set in cable mode and are trying to use an external antenna you will not get anything.
stevekerr
PostPosted: Thu Nov 19, 2009 11:31 am    Post subject: Reply with quote
The TVGOS definitely knows it's hooked up to antenna and not cable.
I can vouch for that because I've been through the setup a couple times after it stopped working and that's one of the setup verifications.
Also, it was working before the switchover on antenna only (we don't have cable).
-Steve
PostPosted: Thu Nov 19, 2009 10:56 pm    Post subject: Reply with quote
please contact to 800-243-0000.
found that here:
http://us.lgservice.com/vchip_html/V-chip_upgrade_for_your_set.html
stevekerr
PostPosted: Sat Dec 12, 2009 11:50 am    Post subject: converter required Reply with quote
Thanks, KUHurdler
I called LG and it turns out I need to buy a converter box to allow the TVGOS to work. $55
http://www.ezdigitaltv.com/Artec_T3APR-T_TVG.html
