Flashing power button on Phillips 60PL9200D   Goto page 1, 2  Next
cleatus
PostPosted: Wed Oct 09, 2013 2:55 pm    Post subject: Flashing power button on Phillips 60PL9200D Reply with quote
Hi All. My mom has an older TV and I'm trying to fix it for her rather than trash it and buy a new one. It's a Phillips 60PL9200D. Originally we were told that it was the main board that needed replacing, costing approx. $300. To top if off, it was on back order as well with no ETA. I found a used one an Ebay and was able to install it. I'm a pretty techie guy and having built several computers, felt comfortable replacing it. After replacing it, I plugged it in and let it sit for few minutes before trying to power it on. When I did try and power it on, I can hear it turn on but then the power button blinks 6 times slow, short pause and then 5 times fast. From the forums I've read and other posts, it seems to lead to the bulb but that was replaced by the tech (supposedly) that said the main board needed replacing. I possibly thought that the travel between my mom's house to the service place, then back to her house, then to my house might of caused the bulb to go bad but wanted to post here and see what others thought before I purchase a new one. I contacted the manufacturer about the flashes power button sequence but they were worthless and just told me I should take it in to get serviced.
Thanks for any suggestions!
PostPosted: Wed Oct 09, 2013 6:32 pm    Post subject: Reply with quote
And you believe the tech would leave a brand new bulb installed in the set?
cleatus
PostPosted: Wed Oct 09, 2013 7:19 pm    Post subject: Reply with quote
No, I don't. But I did take the bulb out and there is no appearance of any hours on it. I also ordered a cheap one off of Amazon (not OEM just to test) and still had the same result in the power light sequence. Thanks for the reply though.
PostPosted: Wed Oct 09, 2013 7:26 pm    Post subject: Reply with quote
You would be amazed at what a known-good "name-brand" bulb can do.
?Did 'Phillips' tech also skimp out?
Also:
Must be from the SAME school of thought as: "I can tell that any electrolytic capacitor is good or bad just by its appearance." Rolling Eyes
CuriousGeorge
PostPosted: Wed Oct 09, 2013 8:05 pm    Post subject: Reply with quote
did you check all caps and fuses? check for hidden boards as well? Have you checked everything with a multimeter?
cleatus
PostPosted: Wed Oct 09, 2013 8:21 pm    Post subject: Reply with quote
I didn't say it was good. I said it appeared that it was. There's a difference there. Again, I'm not a TV repair guy. Just trying to see if I can help my mom fix her TV. I also stated that I replaced it with a new one just to be sure. Maybe in the midst of your sarcasm you overlooked that part of it.
cleatus
PostPosted: Wed Oct 09, 2013 8:23 pm    Post subject: Reply with quote
No I haven't. I'll look there next. I was hoping that the flashing sequence of the power button was a quick indicator to the problem. Does the flashing mean anything at all?
Thanks for replying.
CuriousGeorge
you overlooked my help to insult another member...you must not want her tv repaired too bad
cleatus
PostPosted: Wed Oct 09, 2013 8:36 pm    Post subject: Reply with quote
I did rely to yours as well and I thanked you for the advice. His on the other hand just wanted to poke fun at my lack of knowledge in this area. I take part in many, many programming forums and never do I put someone down that is looking for help. I get that he was pointing out that I shouldn't take the repair guys word with the new bulb. That's why I ordered a new one.
CuriousGeorge
PostPosted: Wed Oct 09, 2013 8:39 pm    Post subject: Reply with quote
im sure the flashing does indicate something. Have you tried looking on google for Philips tv error codes?
Goto page 1, 2  Next
Page 1 of 2
