Gateway 42" Plasma TV FIXED
_Don
PostPosted: Tue May 12, 2009 4:06 pm    Post subject: Gateway 42" Plasma TV FIXED Reply with quote
Thanks for your tip about the burned connector. That cured the problem and probably saved me a lot of grief, as that connector was hidden under a wire bundle. I hope I can help you out sometime.
_Al
PostPosted: Tue May 12, 2009 4:06 pm    Post subject: Reply with quote
Where's the tip?
_Don
PostPosted: Tue May 12, 2009 4:07 pm    Post subject: Reply with quote
The connector is at the top of the set (looking at the the panel with the
back removed). It is hidden under a wire bundle, but if you move the wires, you will plainly see the burned connector. I suggest doing away with the connector & soldering the wires directly to the board
PostPosted: Thu May 21, 2009 4:08 pm    Post subject: Reply with quote
From the above you can only assume the Gateway has only produced one 42" plasma model?
