Posted: Fri Jul 10, 2009 8:08 pm Post subject: |
If you are using a Roof antenna or wabbit ears and tuner is set to receive "broadcast channels" ("up to 69") and you're using it in the U.S. Most of this country switched over to digital broadcasts almost a month ago. That set does NOT have a Digital Tuner, but will work with any of the many DTV boxes widely available. (What cave or hole did you just climb out of?)
If you are using Cable and tuner is set to receive "broadcast channels," you should get stations 2 through 13.
If you are using Cable and tuner is set to receive "cable," the set has a problem.
If you are NOT USING a roof antenna, wabbit ears or cable, irregardless of whether tuner is set to receive "broadcast channels" or "cable," you have a Signal strength problem.
I think that covers all possibilities.  |
