GE 35GT695 Problem with Volume Up
Post new topic   This topic is locked: you cannot edit posts or make replies.    Riddled TV Repair Forum Index -> TV Repair
ron944
PostPosted: Fri Mar 25, 2011 9:56 am    Post subject: GE 35GT695 Problem with Volume Up Reply with quote
Hi, sorry for my previous post I called it an RCA rather than GE. Anyway the volume ramps up to full by itself. I removed the up button and that had no ettect. I cleaned the board and checked continuity on the solder joints for the IC's and they seem okay. I don't know if the Eprom (U3201), Micro Controller (U3101) control this or if it a different IC, any help will be greatly appreciated. Thanks
Ron
PostPosted: Fri Mar 25, 2011 11:12 am    Post subject: Reply with quote
you can edit your original post, but please don't post multiple threads for the same issue.
Post new topic   This topic is locked: you cannot edit posts or make replies.    Riddled TV Repair Forum Index -> TV Repair All times are GMT - 6 Hours
