GE TV 13GP241, TX826TB Dead
Tommy
PostPosted: Sat Aug 18, 2007 6:58 pm    Post subject: GE TV 13GP241, TX826TB Dead Reply with quote
I found tp15 bad, replaced but no go. Volts on tac switches reading 4 volts. Sure could use a schematic and maybe some tips. Help appreciated.
Tommy
JoeJoe
PostPosted: Sat Aug 18, 2007 6:59 pm    Post subject: Reply with quote
TX826
BE SURE TO USE AN ISOLATION TRANSFORMER !!!
THERE ARE POSSIBLE LETHAL VOLTAGES INSIDE!!!
SAMS
3593
3618
3624
3662
3729
3780
3895
3999
DP28-K 1N4004 POWER DIODE part of bridge
This is really earth ground
but the chassis is negative
with the bridge rectifiers
negative leads to chassis
So using chassis as common
there is positive voltage on TP15-C
_RP38 680/2W resistor
__RP39 220/? resistor
___RP40 680/2W
____TP15-C 54.6V be sure to check the configuration on this transistor
_____TP15-E 13.6V source
______TR03-C
_______TR03-E 5V source
Joe
David
Tommy , usually TP11,12, 15, will fix that set. Have the print in paper
only, but will be happy to scan the supply for U if U want it .
Tommy
PostPosted: Sat Aug 18, 2007 7:00 pm    Post subject: Reply with quote
Thanks a lot Joe.
Tommy
Charllo
PostPosted: Mon Feb 04, 2008 2:41 pm    Post subject: Reply with quote
Sir.
I am also having some problems with TV (same model) and I will appreciate any help from you.
Most of all I need a circuit diagram and with a diagram in hand am sure that I can fix the problem..
Can you please help??.
Charllo
silv
PostPosted: Sun Feb 10, 2008 4:41 pm    Post subject: frank Reply with quote
Joe is this TX828 SAMS same as TX809?
Charllo
PostPosted: Sun Feb 24, 2008 7:39 am    Post subject: Reply with quote
Yes Joe
The section in which am interested in that is...
thanks
Charllo
PostPosted: Sat Dec 13, 2008 2:36 pm    Post subject: need to chat with you Reply with quote
Hi David
I would very much like to chat with you.
my set TX826TB will not start...
looking at the base of the horizontal output Transistor the waveform keep
going on and off at one second intervals.
the hi voltage is doing the same thing.
I don't have a diagram and need your expert help.
thanking you.
