GFM v07lcd37 LCD in protection mode
jimroberts0860
PostPosted: Wed Dec 09, 2009 4:40 pm    Post subject: GFM v07lcd37 LCD in protection mode Reply with quote
i have a 37 inch lcd gfm tv that turns on, says "digital tv" in the bottom left corner, and then goes into protection, before it turns off red light blinks 6 times if that means anything. the power/inverter board is the same used in sylvania and maybe others of the same size. with no fuse blowing and no physical signs i don't really know where to start my investigation.
model number: v07lcd37
power board number: ba71g0f01042 (i have seen an identical board listed as ba71g0f01043)
i know a lot of you guys have spent many years of your life learning this stuff, so thanks ahead of time for helping someone trying to get started.
piquahvac
PostPosted: Fri Sep 17, 2010 10:31 pm    Post subject: GFM LCD 37" Reply with quote
Hope this isn't too late, but I also had the same problem. I was just about to junk it, but figured I'd open it to see if I could see anything. Sure enough, right as the digital television display and the bulbs came up, seen a spark on the back left side where all the bulbs' white and red wires were. Seen that a few had melted the plastic and were touching. I jut moved them away from each other, and it fired right up. Hope this helps!
