HELP Emerson LC320EM81 Power
85daytona
PostPosted: Thu Sep 25, 2008 12:02 am    Post subject: HELP Emerson LC320EM81 Power Reply with quote
I think this is a somewhat common problem. The stand by light is on and the screen will power up occasionally but not very often. Usual response is some noise around what I think is the inverter board and the power on light blinks twice. When it does power up it works flawlessly but the getting it on is the hard part...I work on computers not TVs so bare with me here please. How to links or even basic understanding of LCD tvs are welcome.
Thanks, Chris
PostPosted: Thu Sep 25, 2008 11:16 am    Post subject: Reply with quote
You are describing failed capacitors. Remove the power supply and inspect all capacitors 1000MFD and higher for being expanded or pushed up on top. If you see any capacitors with this condition, replacing them will most likely repair your set.
Hope this helps.
85daytona
PostPosted: Thu Sep 25, 2008 3:53 pm    Post subject: Reply with quote
Ok now I'm getting somewhere. When you say remove the power supply what exactly do you mean? What I see in front of me is 3 circuit boards 2 of them have capacitors all over but I don't see any blown or bulged ones. What does the 1000MFD mean?
PostPosted: Fri Sep 26, 2008 2:36 pm    Post subject: Reply with quote
The board you seek is the one with many capacitors and transformers. The capacitors have their value printed on their side. They will be anywhere from 1/8 inch in diameter to 1 inch in diameter. the transformers will be anywhere from 1 to 3 inches square. It is the top of the capacitors that have a tendancy to bulge.
Good Luck
Plasmatech
PostPosted: Mon Dec 08, 2008 11:09 am    Post subject: Solution for LC320EM81, no picture Reply with quote
It is common problem, bad Power-Inverter board.
Usually one or more HV Transformers are bad.
