Hisense 48h5 - aspect ratio question
corvairbob
PostPosted: Sat Jun 09, 2018 3:53 pm    Post subject: Hisense 48h5 - aspect ratio question Reply with quote
i have the 48h5 hisense tv and for some reason i have noticed the aspect ratio is way off. when i watch a program a lot of the picture is out of the frame. i noticed this when watching the network called quest on 2 different tv. one in the kitchen a visio and one in the living room. the hisense is in the living room and i notice the network log they put along the lower right corner all i see is the work quest the a space. in the tv in the kitchen i see quest space and then the q and then more space on the screen. i took pictures if i can figure out how to get them here.
i changed the aspect ratio and the screen does change but everything is relative the the aspect ratio. so in normal aspect i get black bars along the sides of the screen.
has anyone found a repair for this or am i stuck? i believe i need to change the over scan but do not see it in the menu so there must be a back menu i can go into so i can change this over scan. thanks[/url]
PostPosted: Sat Jun 09, 2018 11:34 pm    Post subject: Reply with quote
Sometimes the Cable/Satellite box has their own adjustment controls.
To narrow down further you could swap the boxes or the TVs and see if symptom stays or moves.
corvairbob
PostPosted: Sun Jun 10, 2018 5:57 am    Post subject: Reply with quote
say that could be it. i have the hisense on cable 10 channels and the kitchen on antenna ota channels. they are both the same channel. so what i will do is connect the hisense to ota antenna ans then see if the picture size is the same.
i found a back page but that page did not have an overscan in it, so if there are no more back pages then i'm done but i got to believe there are pages that allow the mfg. to set up the screen size. thanks
