Hitachi 43fdx20b found Stk 392-120's in set ?
thinkoutloud
PostPosted: Sun Nov 08, 2009 10:03 am    Post subject: Hitachi 43fdx20b found Stk 392-120's in set ? Reply with quote
After days of troubleshooting power problem on off I found 392-120 stks
in set . Are these the right ones or wll they work ? 392-110 or 392-150 for this model i beleave are the right ones All so i removed them still have same problem.wont stay on if i disconnect 1 of the power connectors going to either singal board or convergence board then hit power on off switch real fast contiuesley the lamps turn on showiing rgb 3 round circles for about 2 seconds and the more you hit power switch
the bigger they get 4inch cirlces .and you can hear the crts charging
Any ideas please HELP ! AGAIN what stks belong in this set Also i found
RK 50 2.7 ohm on convergence board missing still had 1 lead in board looks like it was cut out for some reason anyone know if this is a mod when useing 392-120 thanks for takeing the time to read this ,
