rocket
Posted: Sat Oct 31, 2009 8:24 pm Post subject: Hitachi 51SWX20B where to go next |
Hitachi 51swx20b, turned set on one morning,red blue and green were way off, so I manuly adjusted red and blue on crosshatch pattern to match green which is non ajustable, the green lines are concave at bottom and the same at top, from what I read in forums I thought I would try replacing the two chips Stk392-110, didn't fix problem where do I go next Thank You |
Posted: Mon Nov 02, 2009 12:54 pm Post subject: |
Carefully observe/check the flameproof low value 1/2 and 1 watt resisitors that are VERY close physically to the STK's. You will find that one of them is open.
rocket
Posted: Mon Nov 02, 2009 9:32 pm Post subject: Hitachi 51swx20b resister fix |
I took Def./Conv./Pwb back out and looked at resisters close to stk chips and there it was a 2.20 om 1 watt resister sightly burned, tested with ohm meter , needle barely moved, have ordered new resisters. can't thank Jesse Mack enough for taking the time to reply to my post. super forum |
