fil131
Posted: Fri Feb 05, 2010 3:21 am Post subject: Hitachi 60" 60SX2K Convergence |
Where can I purchase the 2 STK convergence chips?
Is there a guide somewhere to show me how to replace these parts? |
fil131
Posted: Fri Feb 05, 2010 12:21 pm Post subject: |
I looked in the back of the tv and it does look like I need 3.
Are there any other items I should replace while I am at it?
Thanks for the help. |
Posted: Fri Feb 05, 2010 12:40 pm Post subject: |
check the resistors directly around them. Theyre usually fine, but check them anyway with an ohm meter. Also make sure you use some heatsink compound between the new chips and the heatsink. |
fil131
Posted: Fri Feb 05, 2010 7:02 pm Post subject: |
What are these? SMD caps in digital comb filter
Will I need to replace these too? |
Posted: Fri Feb 05, 2010 10:25 pm Post subject: |
surface mount capacitors. those are extremely difficult to replace. I would not recommend that unless you have any symptoms that require it. What exactly are your symptoms? |
fil131
Posted: Fri Feb 05, 2010 10:54 pm Post subject: |
The colors will not align correctly which is why I purchased the 3 chips.
There is a blue wave kinda light in the upper left hand corner of the screen which I hope may be cured by the Convergence chips.
I will try to take a couple pictures.
Thanks again. |
fil131
Posted: Fri Feb 12, 2010 7:45 pm Post subject: |
Is there anywhere I can find a step by step guide to dissasemble the TV?
I need to get the board out to solder in the chips.
Thanks guys.
Fil |
