Hitachi 60inch 60ux58B projection
BJTV
PostPosted: Tue Dec 09, 2008 7:56 pm    Post subject: Hitachi 60inch 60ux58B projection Reply with quote
Problem with board lights green come on and go off ..Replaced the C707 and the pico 944 still does not power up..I need major help.Miss my TV..Thanks
PostPosted: Tue Dec 09, 2008 8:25 pm    Post subject: Reply with quote
Without Model Number we are all out to lunch (grin)
Model Please
BJTV
PostPosted: Tue Dec 09, 2008 8:29 pm    Post subject: Model is 60ux59 Reply with quote
Model is 60ux59
PostPosted: Wed Dec 10, 2008 10:39 am    Post subject: Reply with quote
Could I get you to confirm the model number? Hitachi shows a ux57 @ 58 but no UX59. Also check the chassis number so we are on the same page.
Just as a guess I looked at the ux57 (the number seven could be mistaken for a 9).
Also, as I do not know what level you are at, I need to ask.
Did you replace C707 because of what you read or because it was bad?
Using the UX7 as model there is no E944 or any E94 anything for that matter so I assumed you mean't E994.
Recheck E994 to see if it has reblown.
If it has, check C701 and D604
BJTV
PostPosted: Wed Dec 10, 2008 4:52 pm    Post subject: Model 60UX58B Reply with quote
Jesse,You are right..This Tv has my mind scrambled..
{Model# is 60UX58B} {Chassis is AP83} {Manufacture date of April 1999} Yes I have replaced the C707 and the E994..Just to make sure what i am doing..Testing for continuity with meter?? If this is correct then yes they all have continuity if it is not.How do i check it the right way..Thanks again for your Time and Help
BJTV
PostPosted: Wed Dec 10, 2008 4:54 pm    Post subject: Reply with quote
Level that i am at is Frustration
PostPosted: Wed Dec 10, 2008 5:38 pm    Post subject: Reply with quote
If you used the ohms scale at a low value (RX1) or (RX10) you should only get a blip on the capacitor. You should not read continued continuity.
The E994 should not make the meter respond at all if it is bad.. It should read 0 Ohms if it is good. On the low scale the capacitor should read infinity. If it does not, it is bad. If you have a capacitor checker built in to your meter make sure your meter has enough range or you will get an erronious reading.
The other two components I listed can also cause the pico sized fuse to open.
BJTV
PostPosted: Wed Dec 10, 2008 6:41 pm    Post subject: Reply with quote
Is it possible to jump around the pico..I am testing right now
BJTV
PostPosted: Wed Dec 10, 2008 6:46 pm    Post subject: Reply with quote
If the pico is open there should be no continuity is I am correct..Maybe wrong I am not a electrical guru.Will continue with what you have said..thanks
PostPosted: Thu Dec 11, 2008 11:41 am    Post subject: Reply with quote
If you jumper the E994 fuse you risk doing more damage. Just measure across at R X 1 scale or if your meter autoranges it will read 000.0 for a good component and will read infinity or quit high, 3K or greater, for a bad component.
