Hitachi L40C205 won't start
lrr250r
PostPosted: Sat Oct 06, 2012 6:09 pm    Post subject: Hitachi L40C205 won't start Reply with quote
Hello all looking for some help with a Tv.
Make - Hitachi
Model - L40C205
power supply part number - RSAG7.820.1673/ROH VER. F
Mainboard part number - RSAG7.820.2107/ROH VER. B
Touch control board part number - RSAG7.820.1833/ROH VER.B
Tv was out on curb for trash a few houses up from me so I snagged it in hopes to save it from the dump.When I plugged it in the tv was completely dead.I removed the back hoping it was just some bad caps on the power supply.What i found was 3 things. The 6.5amp glass fuse was blown and 2 components where cracked.At this point I ordered a power supply from ebay.Now with the power supply replaced the light on the front comes on red.This tv has "touch" controls on it and when i touch where it says power the light on front remains red and nothing happens. I do not have the remote and i tried several universals none of which i got working.I checked for voltages on the power supply connects.At the 5v_s pins i have 4.77 and 4.88 volts.On the stb pin i have 2.09 volts.I don't see any voltage on any other pins,nor any voltage changes on pins when i touch power.I bought a used "working" mainboard to try but that produced the same resuts. i am looking for any help i can get to try and get the set working. I'll post pictures of the boards as well as the connectors on the power supply.Thank you in advance.
lrr250r
PostPosted: Sat Oct 06, 2012 6:18 pm    Post subject: connectors Reply with quote
this connector goes to mainboard only voltage i see is on 5v_s(both) and stb
this connector goes to the mainboard.....no pins show voltage
this connector goes to backlight inverter board...no pins show voltage.
PostPosted: Sat Oct 06, 2012 10:16 pm    Post subject: Reply with quote
See IF the people "a few houses up" have the remote.
Lots of capitalization and punctuation problems and/or many run-on sentences. I'm struggling to understand.
