Hitachi plasma CMP4202U does not power on
Gabe
PostPosted: Sun Sep 20, 2009 1:00 pm    Post subject: Hitachi plasma CMP4202U does not power on Reply with quote
Hitachi CMP4202U , dead.
When powering on , relay click , fans turn about 15 seconds then click and shut off.
Second time powerring on , fans don't turn anymore , and relay clicks twice. Nothing else.
I disconnect the X-sus , nothing change except fans are turning longer (15 seconds each time).
This is our first Hitachi plasma we do.
I don't have s/m.
_Larry
PostPosted: Sun Sep 20, 2009 1:01 pm    Post subject: Reply with quote
does the front panel light flash when it shuts down?
_Vann
found a bulletin regarding "cmp" models from '93 in which
hitachi is stating that some of these models are not
"field" servicable - t
if I'm not mistaken most of these were actually NEC, or am I thinking of
Marantz?
in a lot of these early models you could NOT unplug the y and x boards
separately without damaging the other and then damaging the first when you
tried reconnecting it with the other unplugged - so there is a possiblity
that
if the x and/or y were not bad before, one or both ARE bad now
I know this is true of early Marantz and Pioneer, Pioneer warned of
this in there training sessions
_Gabe
PostPosted: Sun Sep 20, 2009 1:02 pm    Post subject: Reply with quote
Hi Larry
Yes the front LEDs are working , it is red , then turn green at powering on , after 4 seconds it turn red again but flashes orange every 2 seconds.
This plasma turns on , I can see the picture for about a second, then it shuts off , fans stops .
I didn't get any sound , donno if it is because the tv is not running more than a second ...
I did disconnect the sound board , same thing. no changes.
I check all voltages , they are there but only few seconds.
I have the service manual from Hitachi site.
bizarre problem , a bit lost on this one.
