Hitachi Rear Projection 50FX19K not powering on
jaegerdog
PostPosted: Tue Jan 27, 2009 11:04 am    Post subject: Hitachi Rear Projection 50FX19K not powering on Reply with quote
My Hitachi 50FX19K is not powering on. When I push the power button I hear a click but nothing not even the power light on the front. I do see a led on inside the unit, also the top of a transformer looks a little discolored. I think it is T901 a small square transformer that is right next to the words power supply on the board.
Any Ideas? Thanks
PostPosted: Tue Jan 27, 2009 1:16 pm    Post subject: Reply with quote
Sure,
Check fuses, Check Q777 for being shorted, there should be 5 Green LED's on this chassis. If none of them light at the moment of turn-on check ALL fuses.
Hope this helps,
[PugMan]
PostPosted: Mon Mar 30, 2009 4:54 pm    Post subject: H 50fx19k won't turn on Reply with quote
No green LEDs? The only one I see is red when plugged in.
can you tell me where are all the fuses you refer to because I only found 3?
Pleaase please please. I can't afford to pay for repair but I can do soldering
curt wolfe
PostPosted: Sun Apr 12, 2009 8:22 am    Post subject: Reply with quote
Dead non of the 5 green led's light up. red red d975 lights up only. f903 pico [small fuse with leads one it] open & regulator ic901 # strm6511 shorted.
