Hitachii43fdx20B wont turn on relays click on off !
thinkoutloud
PostPosted: Sat Nov 07, 2009 9:10 am    Post subject: Hitachii43fdx20B wont turn on relays click on off ! Reply with quote
Hello thought id see if anyone here has come across this problem ?
liki i said tv wont turn on. checked all fuses all good. leds on deflection board turn on then off found i coud make them stay on by unpluging either
pmr pmg pmb by doing so i lose voltage coming out of flyback if i leave the pm conectors plugged in i can hear flyback try to start up but set shut off go's into protect mode.also if i i unplug signal video board leds will light
but no high votage i have been trying to locate a free service manual with no luck as i already spent 50.00 for this tv as the guy i got this from said
a tech looked at it and the stks 392-120 were causeing this to shut down
is this possible as i have never heard of this on other brands tos.sony philips ect Anyway if anyone can point me in the right direction that would be great. by the way the last hitachi i picked up did the same thing
and i replaced the 3 crt deflection boards as gren board had a bad risistor.thats the only reason i bought this as i thought easy fix nottt.
