Horizontal White Lines on a Mitsubishi CS3515R
MontanaJones
PostPosted: Sat Nov 07, 2009 12:14 pm    Post subject: Horizontal White Lines on a Mitsubishi CS3515R Reply with quote
I'm having this problem with my TV:
from searching the forums it looks like the likely cause is failing capacitors? Anything else it could be? Could anyone suggest the likeliest capacitors to be causing this and where to look for them. Thanks for the help.
PostPosted: Sat Nov 07, 2009 4:11 pm    Post subject: Reply with quote
Most likely (in no particular order):
C4E4 100ufd/35V, C4E5 220ufd/35V, C4E2 100ufd/35V, LA7838 IC
PostPosted: Sat Nov 07, 2009 9:42 pm    Post subject: Reply with quote
agreed, with JTS.
That's called vertical foldover.
MontanaJones
PostPosted: Sat Nov 07, 2009 10:45 pm    Post subject: Reply with quote
thanks for the help, those parts are all dirt cheap fortunately. Is there any possibility it has damaged the screen being operated in this condition for several months?
PostPosted: Sat Nov 07, 2009 11:33 pm    Post subject: Reply with quote
Unlikely. Wink
Now "No vertical sweep" at all for several...that's another story.
MontanaJones
PostPosted: Fri Nov 13, 2009 5:45 pm    Post subject: Reply with quote
Success, my TV is back to normal, thank you.
Fry's stocks that IC, when I started digging into it there was another capacitor that was clearly bad, a 100uF/50V (forgot to note the ID) anyone making this same repair will want to have that cap as well. Thanks again.
