How to replace 3 legs degaus resistor with 2 legs thermistor
sukitlek
PostPosted: Sat Mar 28, 2009 10:11 pm    Post subject: How to replace 3 legs degaus resistor with 2 legs thermistor Reply with quote
My philips TV 27PT6441/37's fuse open after switch on. I found that I have to
"Remove Degauss Resistor 3523 (White Rectangle) And Replace Using
Location 3507 With Service Code 2122 663 00019, A 3 Ohm Ptc Resistor. Give Close Attention To The Marking On The Cba For 3507."
But I am new in electronic. The degauss resistor have 3 legs. The first and second legs locate at 3509 position and the third leg locate on 3507. The new ptc resistor have 2 legs. I don't know which position I have to use for new resistor (Thermistor 2122 663 00019).
Thanks,
Sukit T.
PostPosted: Sat Mar 28, 2009 10:32 pm    Post subject: Reply with quote
Read completely:
http://www.freelists.org/post/techassist/Philips-27pt644137-Blows-fuse,5
PostPosted: Sun Mar 29, 2009 7:40 am    Post subject: Reply with quote
From that link:
Main 4 Amp Fuse Blows At Turn On, Disconnecting The DeGaussing Coil
Eliminates The Fuse From Blowing And The Set Will Operate Normally.
Part 3523 Which Is A Dual Thermister Assbly Is Bad, Part # 2322-662-96753.
Part Is Already Not Available.
Philips Fix Is To Remove 3523 And Install Thermister Part # 2122-663-00019
In Empty Location 3507.
Using Location 3507 With Service Code 2122 663 00019, A 3 Ohm Ptc
Applies To:
26pw6341/37, 27ms6341/37, 27pt5441/37, 27pt6441/37, 27pt6442/37,
30pw6341/37, 32ms6341/37, 32pt5441/37, 32pt6441/37, 32pt6442/37, L04.1u Aa
Symptom: After Replacing Degauss Thermistor (Ptc) 3523 With 3507 As Part
Number 212266300019 , The Fuse 1500 Continues To Open.
Cause: The Wrong Fuse Is Being Used.
Resolution: Use Only Fuse Part Number 242208610914. This Is A Special Time Lag Fuse And Is A Safety Part.
Applies To:
25pt6341/85, 26pw6341/37, 27ms6341/37, 27pt5441/37, 27pt6441/37,
27pt6442/37, 28pw6341/85, 29pt6441/44, 29pt6441/85, 29pt6541/44,
29pt6541/85, 30pw6341/37, 32ms6341/37, 32pt5441/37, 32pt6441/37,
32pt6442/37, 32pw6341/85, 33pt5441/85, L04.1u Aa
sukitlek
PostPosted: Thu Apr 09, 2009 5:48 pm    Post subject: Reply with quote
Thank you. I use 5 amps instead. Everything OK.
