Posted: Mon Sep 07, 2009 3:41 pm Post subject: How to Replace CRT Coolant in a Blurry Rear Projection TV |
http://www.riddledtv.com/journal/CRTCoolant/
just finished this repair walkthrough, although I am sure it will still be revised. I'd appreciate any feedback (good or bad) you have on it.
Thanks
-Jim Riddle
SirSmegalot
Posted: Tue Oct 27, 2009 4:00 pm Post subject: |
I cannot thank you enough for this writeup
I was about to take my tv down to the street now its better than it was new
many thanks
ps- dont syphon the fluid out with a hose and your mouth like I did lol |
coachmatt42
Posted: Sat Jan 30, 2010 12:49 am Post subject: |
I just completed the procedure following the walkthrough. I am have a major problem with the convergence. The blue seems to be too large. Even when I line the cross hairs, the white cross hair is 3/4 the size of the blue. Do you have an idea on how i can adjust this???? This was performed on a 52" phillips 51pp9303h 17.. Thnx Matt |
Posted: Sat Jan 30, 2010 12:01 pm Post subject: |
Turn set off.
Using a small paint brush remove all dust/contamination from the G2/Focus block.
Using a bright light, identify the row of FOCUS controls on the block and identify which color is which.
Remove Screen
Put up center cross or crosshatch.
Looking directly into CRT adjust the focus for that crt for the smallest centercross/crosshatch lines.
Do this for each crt.
Reinstall the main screen.
Put up the centercross and seperate the colors.
Install a piece of typing paper taped over the center cross.
From the back of the set look up at where the centercross is and you should be able to see the individual colors.
Adjust the thumb screw for the smallest line for each corresponding color.
DO NOT ADJUST THIS WITH THE ELECTRONIC ADJUSTMENT ON THE g2 BLOCK. THIS IS THE OPTICAL ADJUSTMENT.
Recombine the centercross.
Hopefully you are fixed.
Jesse. |
coachmatt42
Posted: Sun Jan 31, 2010 1:27 am Post subject: |
Ok i did just as you said an during the convergence process my screen pulsated then shut off. I have the pulsating beep but no power running to crt's.... help!!! By the way i was making corrections from the front of set in sdm.... |
Posted: Sun Jan 31, 2010 7:18 am Post subject: |
Jesse didn't say anything about convergence. What all did you do? |
coachmatt42
Posted: Sun Jan 31, 2010 9:44 am Post subject: |
I preformed a coolant change on the blue and green guns of a phillips 51pp9303h 17. I was in sdm mode doing the convergence when the screen flickered a couple of times then shut off. When I turn the set back on i get a constant beeping sound but no power to crt's..... |
Posted: Mon Feb 01, 2010 1:11 pm Post subject: |
Unplug the set and let it reset, plug back in and set may come back on. If you followed the fluid change directions you certainly do not need to go into any of the service menu's. The normal consumer menu is all that you need.
Hope this helps.
coachmatt42
Posted: Mon Feb 01, 2010 3:45 pm Post subject: |
I hope so, but this is just my tinker set. I think the blue crt is arcing. I cant figure out where it is coming from... |
Posted: Mon Feb 01, 2010 6:06 pm Post subject: |
If you have coolant leaking into the yoke windings you will start arcing between the yoke and the crt and will not be able to visably see the arc.
Only way to check this is to remove the yoke and clean crt and yoke - you usually can see a possible burn spot on the yoke. Sometimes this can be corrected with silicone if it has not progressed to far.
Hope this helps.
