riyazbasha69
Posted: Sun Jan 23, 2011 8:56 am Post subject: How to replace Tuner in Sony KV-J21PF1 |
Pls can anyone say how t replace Tv Tuner in Sony TV ,
regards
riyaz |
Posted: Sun Jan 23, 2011 3:30 pm Post subject: |
any particular model? or just any sony? |
Posted: Sun Jan 23, 2011 8:49 pm Post subject: |
Rotary or electronic? |
riyazbasha69
Posted: Sun Jan 23, 2011 8:57 pm Post subject: How to replace TV Tuner in Sony TV |
Sony Trinitron Tv
Model : KV - J21PF1
thanks for the reply . |
Posted: Sun Jan 23, 2011 9:17 pm Post subject: |
I don't have any info on that model. Can you take a look at the silver box on in the TV that the coaxial cable connects to? there should be some numbers on it that identify what to replace. Can you post back with the numbers you find? |
Posted: Sun Jan 23, 2011 9:18 pm Post subject: |
TU101: Remove as much solder as possible from all pins and corner/mounts. Try to get so each pin/mount "moves" freely. Some corner/mounts may need to be straightened. Carefully remove from the mother board (A). Install the replacement in reverse order.  |
riyazbasha69
Posted: Sun Jan 23, 2011 10:36 pm Post subject: How to replace TV Tuner in Sony TV |
I have removed the TV tuner , And i have replace a new TV Tuner in the same place in same way , but also cable channels its not coming....
thanks for reply .
riyaz. |
Posted: Mon Jan 24, 2011 12:06 am Post subject: |
Was the symptom the same with the original tuner? |
riyazbasha69
Posted: Mon Jan 24, 2011 12:34 am Post subject: How to replace TV Tuner in Sony TV |
Yes , |
Posted: Mon Jan 24, 2011 1:24 am Post subject: |
Sony won't tune cable? Assuming it WILL tune "Broadcast stations" and any audio/video inputs.
Possible problem ... Possible solution
No Cable to domicile ... Have Cable installed.
Unit not being used/worked correctly ... Read user manual regarding proper operation.
Television defective ... Troubleshoot and repair microprocessor (tuner control), could even be missing a power supply source to those areas. |
