How To Reset Samsung CS-63750PF Without Service Menu
Satelster
PostPosted: Thu Dec 27, 2007 2:52 pm    Post subject: How To Reset Samsung CS-63750PF Without Service Menu Reply with quote
My TV Can not Start Correctly & Auto Power Off After 1 - 2 Seconds
So I can't use service menu
How To Reset Samsung CS63750 Without Service Menu ?
Is it any way to short pin's of EEPROM ?
Or Any Trick For This Problem ?
PostPosted: Thu Dec 27, 2007 7:50 pm    Post subject: Reply with quote
you should probably try and figure out what is making it turn off and forget about the service menu.
I'd guess that there is some voltage that is out of tolerance. I've never heard of your model number though. Can you double check it?
Satelster
PostPosted: Fri Dec 28, 2007 2:33 am    Post subject: Reply with quote
I take 2 pictures from Front & Back of my TV
This is CS-63750PF !
This problem ACCIDENCE after X-Ray:OFF -> ON on the Service Menu > Options !
Help ! :(
PostPosted: Fri Dec 28, 2007 9:30 pm    Post subject: Reply with quote
I can't find any info on your specific model. but Id suggest jumpering accross the relay that shuts off... keeping it on long enough to change that value back.
make sure not to do it long-term.
Satelster
PostPosted: Mon Dec 31, 2007 11:47 am    Post subject: Reply with quote
I found very good trick to disable this option !
with very simple & small circuit & use in my TV mainboard all settings runs at default !
than I can to change all wrong value to default & power off
so remove circuit & TV Can work normally
Used Component: 2 x 1K Resistor ( Just for 10 minute ! :D )
PostPosted: Mon Dec 31, 2007 4:32 pm    Post subject: Reply with quote
great.
would you like to share the specifics of what you did?
norrih
PostPosted: Wed Jan 21, 2009 7:22 am    Post subject: Reply with quote
Hi Salester,
I made the same mistake, I put the X ray on on my samsung crt tv,
can you please share your solution.
Thanks a lot
Norrih
