How to unlock Toshiba 32PB1E panel lock?
Toshiba32PB1E
PostPosted: Fri Jul 11, 2014 6:51 pm    Post subject: How to unlock Toshiba 32PB1E panel lock? Reply with quote
All panel Toshiba 32PB1E are locked on TV and remote control except remote control POWER button only including MENU button on both TV and remote control.
How to unlock all these button as only remote control POWER button is just working??
PostPosted: Fri Jul 11, 2014 7:40 pm    Post subject: Reply with quote
Page #20 of User Manual has:
Panel Lock
Panel Lock disables the buttons on the TV. All
buttons on the remote control can still be used.
1 From the FUNCTION menu, press arrow up or arrow down to
select Panel Lock.
2 Press left arrow or right arrow to select On or Off.
Note:
When Panel Lock is On, a reminder will appear
when the buttons on the TV are pressed.
If the standby button is pressed, the TV will
switch off and can only be brought out of standby
by using the remote control.
Certain buttons on the remote could be not working/have to press hard due to old age? If so, try refurbishing (clean buttons & contact areas) inside remote or obtain a replacement remote.
