HP LT4700 LCD Model CPT0H-0708 Thick Vertical Lines
ntehicks
PostPosted: Wed Feb 16, 2011 3:20 pm    Post subject: HP LT4700 LCD Model CPT0H-0708 Thick Vertical Lines Reply with quote
This LCD TV HPLT4700 had a great picture until we moved. Since the move it started with 2 thin lines about 3 inches apart on the far left side of the screen. Now it has completed together. So there is a 3 inch line now and it is starting on the right side as well. Has anyone seen something like this? I don't know if it could be a loose ribbon cable or maybe capacitors?
thanks for any info on this matter.
murfy888
PostPosted: Fri Mar 04, 2011 1:43 am    Post subject: Reply with quote
Check loose connections maybe cause by vibrations while you moved. Check for loose contacts and resolder suspected loosed parts.
