Insignia INP4219 plasma does not power on   Goto page 1, 2  Next
_Gabe
PostPosted: Thu Feb 26, 2009 12:08 pm    Post subject: Insignia INP4219 plasma does not power on Reply with quote
Got this Insigna plasma INP4219 that when powering on makes a little thump in the speakers then shuts down.
Check all fuses ok , no component burnt , checked many transistors in power supply ok.
Don't really know where to start or look at in this one.
Any hints welcome,
TIA
_Bill
PostPosted: Thu Feb 26, 2009 12:08 pm    Post subject: Reply with quote
did you check to see if any of the capacitors are puffy in the power
supply
bill
_Peggs
PostPosted: Thu Feb 26, 2009 12:09 pm    Post subject: Reply with quote
start by checking resistance to gnd on the PS connectors..........then disconnect PCB's one at a time
_Gabe
Bill , I had check for that , and no , all caps are ok , no one bulged.
_Gabe
PostPosted: Thu Feb 26, 2009 12:10 pm    Post subject: Reply with quote
Peggs , I have check the resistance to ground at P5 connector (you had suggested connector PS, I can't find it).
Resistance looks shorted to ground. I have check VS pin to Grnd.
But the fuse is good , removing the fuse , tv stays on (blue led) but nothing .
Putting the fuse back , I can hear a faint buzz from power supply , and led return to red , and cycle again.
Thus removing the big connector going to Ysus , no more faint buzz of the power supply.
By the way ,this Insignia has all LG boards and stuff inside.
Thanks
_Tito
If that Insignia is like LG, I have several's boards for LG 50",if you need
one,give me a number and I will check if I got it and you can Borrow it from
us to test .- Tito
_Peggs
PS stands for Power Supply..........
check resistance to gnd on ALL connectors !!!.......if you find a short,unplug pcb's til it's gone.......then you'll be headed in the right direction.......
Peggs
_Gabe
PostPosted: Thu Feb 26, 2009 12:11 pm    Post subject: Reply with quote
Had work a bit on this one , disconnecting the YSUS makes this tv stay on (blue led).
I found in my junk another Ysus board , and switched it , now blue LED stays on , but no pic (only hear a pussshhh in speakers for a second), that's all (nothing ,no osd).
All inside tells it is a LG tv.
What can be wrong in the Ysus (everything I check seems good) ?? is there any rebuilders for these boards ? Can I have a way to illuminate the screen to check ? ........ ? ..... ? ....... ?
TIA
_Aaron
PostPosted: Thu Feb 26, 2009 12:12 pm    Post subject: Reply with quote
The Y board wouldn't happen to be a Samsung # LJ92-001200A would it?
I've got a set in here with the very same problem-
_Doug
Sounds like you both have bad buffers along with bad YSUS. Common problem
for the Samsung. Not enough info for the LG made unit.
Goto page 1, 2  Next
Page 1 of 2
