insignia not coming on question
corvairbob
PostPosted: Mon Dec 26, 2022 3:27 pm    Post subject: insignia not coming on question Reply with quote
i have a neighbors insignia tv he dropped off to see if maybe i can figure out it not turning on.
the model is the ns-40dr420na16
i took the power board out and i have 120 up the the filter cap and then because i do nothave any more test point i went to the cold side and i have no 12 volt or 33 volts at the connector that could be 3.3 volts hard to read that number. i did not measure the 2 wires that go into the screen yet. they could be the leds but i have not got quite that far. so i suspect the power supply is bad based on no 12 volt or 33 volts at the 12 pin connector
have to figure out how to post the photo of the power board.
https://www.dropbox.com/s/g38lt213gqdl0eb/20221226_150312-1.jpg?dl=0
https://www.dropbox.com/s/fn9nina2gpppde6/20221226_150312.jpg?dl=0
corvairbob
PostPosted: Tue Jan 03, 2023 7:44 am    Post subject: Reply with quote
ok it looks like no one has a good answer. i was hopping to get a schematic that has test points so i can look for voltage and see if i can find the fault. i did unplug the main board and the led from the power board just in case one of those might be pulling the power down but i still did not get and power at the connections powerpoints. i have power on the hot side around the filter cap i have 168 volts then it drops after the power reduction transformer.
anway i guess i will just look for a used board and see if that does the trick. thanks
