JBL DPS-12 Digital Subwoofer cabinet keeps blowing a fuse?
foxhunter37
PostPosted: Wed Apr 08, 2009 6:15 pm    Post subject: JBL DPS-12 Digital Subwoofer cabinet keeps blowing a fuse? Reply with quote
I had this cabinet giving to me and all it wants to do is blow fuses.I would appreciate any help in the right direction as I would hate to throw away such a nice speaker cabinet.Thank you all very much Russ
PostPosted: Thu Apr 09, 2009 6:31 am    Post subject: Reply with quote
I'd assume there is a short in the power transistors in the amplifier.
PostPosted: Thu Apr 09, 2009 11:46 am    Post subject: Reply with quote
Or power supply?
foxhunter37
PostPosted: Thu Apr 09, 2009 8:59 pm    Post subject: Reply with quote
thank you both for the replies.Is this something I can fix on my own or would I have to replace the whole board and make it easier and is there such a place to buy this type of parts from?
PostPosted: Thu Apr 09, 2009 9:14 pm    Post subject: Reply with quote
If you've got the desoldering/soldering skills, a multimeter and patience, you should be able to attempt it.
If the unit is more than a year or two old, the manufacturer may not be of much help as far as buying parts or replacing the whole board. If the unit uses proprietary parts (I.C.s / transistors), you may also have some difficulty.
Just google number on part. Results should point to a number of possible sources.
foxhunter37
PostPosted: Thu Apr 09, 2009 10:44 pm    Post subject: Reply with quote
Thank you JTS1957 I do know a little about soldering techniques and I am similar to most components and circuits.I hope JBL will have a schematic to download and go by if I need any help identifying the part number beneficial to this repair.Thanks again....
