Webslinger
Posted: Wed Nov 17, 2010 9:09 am Post subject: JVC AV-32890 Screen is black and popping sounds |
JVC AV-32890 32 in. (no chassis number could be found) purchased in 1997. TV has worked great until two days ago. I had left it on downstairs while I finished dinner. The program the TV was turned to was on and could be heard from upstairs. After some time, I began hearing popping noises coming from downstairs. Went to investigate and found the TV's picture screen to be black/dark and the popping sounds were coming from the TV speakers. The indicator light located under the 'power on' button was dark. It is normally lit up red.
I used the remote control and the 'power on' button to try and turn the TV off and on, but nothing happened except continuous random popping. The popping stopped once I unplugged the power chord.
I have tried leaving the TV unplugged several times (a few minutes, an hour and overnight) then plugged it back in to see if it works. I get nothing. Screen remains black/dark and popping noises occur, though not as bad as at first.
Any ideas?
Thanks for your help! |
