JVC AV28GH1BUF, no straight image
mbertens
PostPosted: Fri Jan 08, 2010 5:13 pm    Post subject: JVC AV28GH1BUF, no straight image Reply with quote
Hi,
Who can help me with this problem my JVC tv has a couple of days this problem (see picture)
I have a service manual, but this does not completely matches the TV it self, different FEATURE BOX PWB.
Ajusting the PARAB option in de service menu does'nt any thing. the potmeter inside the TV gives some effect on the image but not enough.
[img]http://i1008.photobucket.com/albums/af205/mbertens/20012008343.jpg?t=1262992017[/img]
PostPosted: Fri Jan 08, 2010 7:27 pm    Post subject: Reply with quote
Perhaps it has a defective part?
Time to use that service manual to troubleshoot the set, rather than hope that adjusting some parameter in the service menu will correct your problem. Rolling Eyes
mbertens
PostPosted: Sat Jan 09, 2010 1:50 am    Post subject: of cource.... Reply with quote
Of course its a defect part, but i don't know how to troubleshoot the problem. De description i gave is for helping you guys understand what the problem might be.
I hope that are people here that give better advice then you JTS1957
PostPosted: Sat Jan 09, 2010 5:12 pm    Post subject: Reply with quote
Gee i know im certainly chomping at the bit to help after reading that comment. Good luck to ya
PostPosted: Wed Jan 13, 2010 12:15 pm    Post subject: Reply with quote
Come on fellas, maybe its a language problem:
Quote:
If my car develops a miss in the engine I think I will just adjust the electronic engine controls.
Sir, Your set has a pincussion problem and will require component level repairs. I would suggest you take it to someone that has at least some knowledge of electronics.
