JVC JLE55SP4000 - No Sound During TV Mode
memsr
PostPosted: Thu Aug 20, 2015 8:32 am    Post subject: JVC JLE55SP4000 - No Sound During TV Mode Reply with quote
JVC 55" TV
Model #: JLE55SP4000
In TV mode, there is no sound. When I switch to the Pandora app, sound is normal. I called JVC support and was told they could send a tech to replace the main board...part # 3655-0482-150.
Somewhere I read that the main board for Model # JLE55SP4000B (part # 3655-0682-0395) is a replacement for 3655-0482-150. After receiving the replacement board, I realized that it only has 2 speaker connectors instead of the 3 that are on the original board 3655-0482-150.
Question 1: Is replacing the main board the solution to the no sound problem during TV mode?
Question 2: If the answer to Question 1 is YES, will main board 3655-0682-0395 work in my TV (JLE55SP4000)?
Question 3: If the answer to Question 2 is YES, what (if anything) do I do with the 3rd speaker connector?
Thanks in advance for any and all help!!
PostPosted: Thu Aug 20, 2015 11:25 am    Post subject: Reply with quote
Define: TV mode
DTV/Cable/Antenna - RF?
Set the TV Mode in Channel menu.?
Set top box Cable/Satellite - HDMI?
On Viewing Mode screen, select desired TV mode, and then press OK button.?
OTHER?
______________________________________
FURTHER:
memsr wrote:
JVC JLE55SP4000: No Sound During TV Mode
Since JVC offers a separate Owners Manual download for each model, I'll assume that even they believe there is a substantial DIFFERENCE between the two. (Board part numbers due to features supported would be a good guess.)
memsr
PostPosted: Thu Aug 20, 2015 11:45 am    Post subject: Reply with quote
My definition of TV mode is a connection to an AT&T Uverse set top box and HDMI. Access to Pandora is via the JVC ICE (Internet Connected Experience) which is a selection on the TV remote.
PostPosted: Thu Aug 20, 2015 12:51 pm    Post subject: Reply with quote
Does 'AT&T Uverse set top box and HDMI' when connected to another HDMI Input On your set produce sound?
Or better yet ...
Does 'AT&T Uverse set top box and HDMI' when connected to ANOTHER TV's HDMI Input produce sound?
memsr
PostPosted: Wed Aug 26, 2015 3:26 am    Post subject: Reply with quote
Many thanks to JTS1957!!! The set top box was the problem. I presumed JVC had experienced this no audio problem previously and knew replacing the main circuit board was the solution. I won't make that mistake again.
Best regards,
