JVC LCD lt 32dy8zj dark pic and slow moving images
jamie07
PostPosted: Wed Dec 21, 2011 9:46 am    Post subject: JVC LCD lt 32dy8zj dark pic and slow moving images Reply with quote
Hi,
MODEL: JVC lt 32dy8zj 32inch LCD tv
My son was playing xbox 360 and all of a sudden some weird colours started to come on tv and after few days It went all dark and you can hardly see thing..
Also there is slow moving images like slow motion..
I tried adjusting all the colours etc but no luck..
I tried researching the problem aswell and found that others had the same problem in past but couldn't find the solution there..
Any help would be really appreciated.
Thank you very much in advance.
CelicaSupra
PostPosted: Wed Dec 21, 2011 10:11 am    Post subject: Reply with quote
most likely the t-con board from the symptoms you describe, seems to be a fairly common LCD tv failure point from my experiences & Ebay etc is littered with people/companies selling reclaimed boards for relatively little cash. The better companies even offer a warranty period.
(this assumes the "going dark" you mentioned is not the backlight going out, does the screen glow when switched on in a dark room? if not then the backlight is also out in conjunction with the slow motion/wierd colours etc and then I'd say the mainboard would be more likely)
Would be interesting to know the make of the panel & t-con since it always seems (at least to me!) to be 32" models & inevitably the ones ive seen are mostly made by LG
