JVC LT-37X688 - Flashing purple tint
hueydj
PostPosted: Tue Mar 04, 2014 11:21 pm    Post subject: JVC LT-37X688 - Flashing purple tint Reply with quote
Hello, I would really like some guidance/help about what is going on with my TV that is connected to my. Over the past year or two my JVC Genessa 37" LT-37X688 has behaved oddly when I turn it on or switch inputs. It would start with the right half of the screen tinged purple(not divided perfectly down the center with a straight line, but curved). The purple would then recede over about 5 seconds or so and the TV would be fine. Nothing changed for probably close to a year. Then this started happening https://www.youtube.com/watch?v=YIrPmAfTDQo During just normal TV watching (connected to a computer) this occurs sporadically. Maybe a couple times a day or nothing for a couple days. Any thoughts on what component is failing that would cause this? About a month ago I took the TV apart for the first time to clean it (it was very dusty) and to check the connections. Nothing was loose but the behavior seemed to stop for a couple weeks. Now its back again. I'd really like to salvage this TV because I can't find a nice TV with a matte screen. Thanks for any help.
PostPosted: Tue Mar 04, 2014 11:38 pm    Post subject: Reply with quote
Start by looking visually for any puffed or leaky electrolytic capacitors, especially on power supply board. Next if tcon board uses flat ribbon-type cable connectors instead of plug/socket ones, you could try unplugging and cleaning the ends of these cables.
